• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Distinguished Contributor
    Soft Metric HVAC Label
    173 Views, 5 Replies
    08-05-2012 04:41 PM
    I'm looking for a Soft Metric label to tag the HVAC components in an imperial unit drawing. Does anyone have this or know how to create it?
    Please use plain text.
    Product Support
    Re: Soft Metric HVAC Label
    08-08-2012 01:10 PM in reply to: RocksterB
    Randy,
    This set of YouTube videos will show how to make a Tag.  The biggest thing users run into is tag scaling with the annotative scales, but the set of 4 videos addresses the "How-To" make a tag which I think will work here.  Hope this helps,
    Joshua
    Link:
    http://www.youtube.com/playlist?list=PL99839E19EF2CE88D&feature=plcp
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Product Support
    08-10-2012 12:57 PM in reply to: RocksterB
    Hey Randy, were those videos useful?
    Joshua
    Joshua Benoist, PE
    Product Support
    08-12-2012 10:12 AM in reply to: RocksterB
    Not in this case. I have an imperial unit drawing that contains a ductwork layout. By default, an imperial label is added desplaying the imperila unit size. I need a tag or label that will also show text in soft metric text.
    Product Support
    08-13-2012 06:22 AM in reply to: RocksterB
    One word (ok 2), Property Sets.
    Method 1:
    Use a formula property to manually convert the units.  2.54 cm = 1 inch.
    Method 2:
    Use a property set > property, mapped to a property data format that uses metric units.  See image.
    http://screencast.com/t/PSyoi67139Xo
    HTH,
    Joshua
    Joshua Benoist, PE
    Product Support
    08-13-2012 07:53 AM in reply to: Joshua.Benoist
    I used a modified version of your Method 2. I had to create addtional property sets and create a new tag. Thanks for your help.
