• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *Dillon, Matt
    Smiley Faces?
    75 Views, 6 Replies
    05-30-2003 02:59 AM
    I have both ADT 2004 and ABS 2004 loaded, and I have the CAD Manager
    pull-down and toolbar loaded in both. In ADT the CAD Manager toolbar is
    fine, in ABS, the Display Manager, Style Manager and Visual Audit buttons
    have the question mark icon indicating the image can't be found. I tried
    re-compiling the mns, mnr and mnc files from the mnu and reloading but no
    luck.
    Matt Dillon
    Assistant Moderator: Autodesk Discussion Forums
    Please use plain text.
    Distinguished Contributor
    Re: Smiley Faces?
    05-30-2003 03:20 AM in reply to: *Dillon, Matt
    Sounds like you are doubling your efforts and maybe the menus have been overwritten a bit. Speaking from a BS3 stand point I am not positive on BS4, but within BS3, a full version of ADT is included. So there was no reason to install a separate copy of ADT 3.3. In fact it potentially caused problems to have both loaded.
    *Dillon, Matt
    Re:
    05-30-2003 03:47 AM in reply to: *Dillon, Matt
    True, for most people, however I must be able to support both architects and
    mep engineers. I need to have an ADT that is not populated by ABS, and vice
    versa. Which is why I never loaded them on the same machine in 3.3 (you
    couldn't). With 2004, it doesn't seem to be a problem, except for possibly
    this, which I could live with. Interesting though, since I installed ADT
    before ABS, and it's ABS that is not finding the icons.
    Matt Dillon
    "jmcfaddn" wrote in message
    news:f1690c1.0@WebX.maYIadrTaRb...
    *[Autodesk], jason martin
    Re:
    06-02-2003 09:46 PM in reply to: *Dillon, Matt
    Hi Matt -
    Have you recompiled the ABS menu's (our are named different than the
    standard ADT ones)?
    Please post back if it doesn't work.
    jason
    "Matt Dillon" wrote in message
    news:E219101E7D846ED45910AF98B65B47EB@in.WebX.maYIadrTaRb...
    and
    vice
    > Matt Dillon
    BS4,
    to
    *Dillon, Matt
    Re:
    06-02-2003 10:25 PM in reply to: *Dillon, Matt
    I tried that first off, Jason, the ABSCadManager MNC, MNS and MNR were all
    deleted leaving only the MNL and MNU files, menu unloaded from the
    interface, then reloaded. No change.
    Interesting. But not insurmountable. I'll just save the images from the ADT
    interface and apply them as images to the toolbar buttons in the ABS
    application.
    Thanks.
    Matt Dillon
    "jason martin [Autodesk]" wrote in message
    news:5D7161842532BD60699D4A35B5DEFCA7@in.WebX.maYIadrTaRb...
    > Hi Matt -
    > standard ADT ones)?
    > jason
    > and
    > vice
    possibly
    > > Matt Dillon
    > BS4,
    reason
    > to
    problems
    Re:
    06-03-2003 01:01 AM in reply to: *Dillon, Matt
    DOH!!
    Looks like the install is missing a required .dll for those images. Do what
    you did before (delete all the cad manager .mnc, mns, and mnr files) the
    copy that ADTCadManager.dll and name it ABSCadManager.dll. Now reload the
    menus. Image should appear.
    Thanks Matt!
    jason
    news:93A38803385B1EC6DE0ED7C701A1900C@in.WebX.maYIadrTaRb...
    ADT
    > application.
    > Thanks.
    > Matt Dillon
    *Dillon, Matt
    Re:
    06-03-2003 01:10 AM in reply to: *Dillon, Matt
    That fixed it! Thank YOU, Jason :-)
    Matt Dillon
    news:1B87702869F4BF002CBDF5BD95009ED8@in.WebX.maYIadrTaRb...
    > DOH!!
    what
    > Thanks Matt!
    > jason
    all
    > ADT
    > > application.
    > > Thanks.
    > > Matt Dillon
