AutoCAD MEP
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with solids plots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
2 users both running AutoCAD MEP2012 on Win7 Pro 64 bit systems. Printing to older HP DesignJet 500 through local USB port on one system, shared to other system. Users are getting lines across the page whenever print solids. Does not have the problem when printing 2dy frame (hope this makes sense, I don't use the software, just trying to find a solution to the problem). DJ is installed as HP DJ500 42 + HPGL2 card, driver is latest per HP website, HP DJ Printer Driver v7.10. Lines do not show up in Print Preview. Did not have this problem with 2011 version, showed up when they updated to 2012 version.
All guidance and suggestions welcome!
Re: Problem with solids plots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This missing linework issue was addressed with 2012 service pack 2. Install SP-2 and type this at the command line: HIDEPRECISION = 1. The system variable opens up the plot memory storage to use higher precision values which helps it discern one line from another. They do not occlude each other when close together. They reappear.
Hope this helps.
Joshua
__________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Support Specialist
Product Support
