• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Valued Contributor
    Printing without borders around xrefs pdf and jpeg
    2415 Views, 1 Replies
    10-04-2010 08:50 AM
    I have a drawing with an xref'd title block and an xref'd pdf document (among other things). The titleblock drawing als has an xref'd logo in jpeg format.  I turned the lines white (RGB 255,255,255) in the properties of the logo xref and pdf xref so the drawing would print without a border around them. This worked fine until recently. The border started showing up in black ink even though the border is designated white. The only thing I think I did differently that may have caused it was to accendentally click print preview when the printer/plotter was set to DWF55 ePlot (optimized for plotting).pc3. After that the border started showing up even when I changed the printer/plotter to the usual plotter I use.
    Any ideas how to fix this and/or a better way to print without borders around jpeg's and pdf's?
    Useing AutoCAD MEP 2010, but a suggestion that works in another version is welcome.
    Please use plain text.
    *Expert Elite*
    Keith.Brown
    Re: Printing without borders around xrefs pdf and jpeg
    10-04-2010 10:02 AM in reply to: aacorley
    I am not sure about the xref's and pdf's but for jpegs you can type IMAGEFRAME and set the variable to 0.  This will turn off frames around images.
    Keith Brown AutoCAD MEP BLOG | RSS Feed
