• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Valued Mentor
    Accepted Solution
    PreDelivered HIGH PRECISION Property Data Format is completely wrong.
    251 Views, 1 Replies
    09-19-2012 12:55 PM
    I've discovered that HIGH PRECISION is incorrectly setup...
    The Precision value is 0.0000000 which is correct... but the Leading and, in particular Trailing Zero Suppression should not be turned off... a value of 10.000 comes across as an integer and not as a decimal... this prevents proper resolution of calculations in a formula property... at least in my case.
    Can you fix this in a subsequent release or SP?
    Please use plain text.
    Product Support
    Re: PreDelivered HIGH PRECISION Property Data Format is completely wrong.
    09-20-2012 02:07 PM in reply to: mdhutchinson
    Mike,
    The High Precision property data format is used by some properties in the  set called "DuctEngineeringData."  This is a specialty hard coded property set that our duct objects interface with.  We change this, it's likely to break other unintentional areas.  You should create a new property data format based on High Precision that is set your way.  It can reside in your template and would always be available.
    Joshua
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
