• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD MEP
    *Popiel, Slawomir
    Plumbing pipe catalog
    413 Views, 4 Replies
    06-30-2003 05:32 AM
    There are only brazed, glued and threaded pipes in plumbing catalog. Is it
    something wrong with my setup?
    sp
    Please use plain text.
    *Popiel, Slawomir
    Re: Plumbing pipe catalog
    06-30-2003 05:37 AM in reply to: *Popiel, Slawomir
    "Slawomir Popiel" wrote in message
    news:E0C7E8E2F5B558DA4989CE6739E53CC0@in.WebX.maYIadrTaRb...
    > sp
    Correction:
    I have identical set of pipes as above, in both plumbing and piping catalog.
    Somehow disppeared such pipes like flaged, welded, etc.
    Anybody cares to comment on that?
    sp
    *[Autodesk], Bo Noren
    Re:
    06-30-2003 11:36 PM in reply to: *Popiel, Slawomir
    Hi Slawomir,
    No, it is nothing wrong with your setup. The Plumbing Pipe US Imperial
    catalog does only contain pipes for those connection types.
    I think that the pipes that exists in both catalogs are the same; it is the
    fittings that are different.
    Does that answer your question?
    /Bosse
    news:AC83D6E1DF38B012BE37495A806A4FE6@in.WebX.maYIadrTaRb...
    it
    > > sp
    > Correction:
    catalog.
    > sp
    *Popiel, Slawomir
    Re:
    07-01-2003 04:34 AM in reply to: *Popiel, Slawomir
    "Bo Noren [Autodesk]" wrote in message
    news:E2C7332833212C435D0E0FDE48FDF48A@in.WebX.maYIadrTaRb...
    > Hi Slawomir,
    the
    Yes and no.
    Can't figure out why flanged or welded piping does not exist anymore. What
    was wrong with having it?
    Will pipes from ABS3 work with ABS2004? In other words, how about copying
    proper folders yto ABS2004 location?
    sp
    Re:
    07-01-2003 03:57 PM in reply to: *Popiel, Slawomir
    Hi Slawomir,
    The Pipe US Imperial (and Metric) catalogs still contain pipes and fittings
    for all connection types. In BS 2004 there is an additional catalog Plumbing
    Pipe US Imperial that only contain a few connection types and have other
    types of fittings. You shouldn't have to copy the pipe catalogs from ABS3,
    the one in ABS 2004 contain the same pipes and fittings. Which catalog are
    you using? Are some connection types still missing after switching to Pipe
    US Imperial catalog?
    /Bosse
    news:53445EF22DAACE9853E179F6B1982442@in.WebX.maYIadrTaRb...
    > > Hi Slawomir,
    > the
    > Yes and no.
    > Thanks
    > sp
