• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *Cox, Laura
    Plumbing Fixture Labels
    297 Views, 1 Replies
    06-26-2003 09:42 PM
    I am trying to label a plumbing fixture using the fixture label from the
    palette. Tha label looks correct when in the process of inserting it but
    when I accept the location for the tag all that is visible are two lines.
    Can anyone tell me what I'm doing wrong?
    Please use plain text.
    *[Autodesk], Fredrik Andersson
    Re: Plumbing Fixture Labels
    09-02-2003 11:27 PM in reply to: *Cox, Laura
    Hi Laura
    What you see is a underlined hyphen...
    This happens because default "Name" of the tag is "-".
    Please see help file > Building Systems 2004 Help > Building Systems
    Tutorial > Plumbing Tutorial >
    Lesson 9 - Exercise 1: Adding Schedule Tags to Fixture..
    The key to success is to add a name for Item during the process of adding
    the tag.
    If you would like "P - 1" (or anything else) as default setting when using
    the Fixture Tag, try this:
    1. Start Design Center and select the Custom tab
    2. Browse to Imperial > Documentation > Schedule Tags > Plumbing Tags
    3. Right click "Fixture Tag 4" and select Open from Pop up menu
    4. On command line type "AecpropertysetDefine" and then press enter
    5. Right click "MvParts-FixtureUnits-Objects" and select Edit.
    6. On definition tab, select Item. Change default value from "-" to "P-1"
    (or anything else)
    7. Please make a backup of the drawing file before saving.
    Regards
    Fredrik Andersson
    "Laura Cox" wrote in message
    news:C4C8A47C9774E9583E0D6761F5CA5348@in.WebX.maYIadrTaRb...
    > Thanks
