• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    Piping: Has any one used piping objects for cost estimating?
    70 Views, 2 Replies
    11-18-2003 11:42 AM
    I would like to either export piping information for cost estimating to excel, or report the data to a schedule. I would like to know if there is an easier way of generating cost information for a pipe run. I have used the style manager and made a property set definition calculation formula, but I am having problems with different cost factors on different sizes of pipe.
    Is VB the best way, or is there something I am missing? Or is there an easier way?
    Please use plain text.
    *[Autodesk], Hakan Wikemar
    Re: Piping: Has any one used piping objects for cost estimating?
    11-19-2003 03:56 PM in reply to: DBares
    Hi DBares!
    Formulas should be able to do the trick for you
    with some VB in it (some if or case things should do the trick). If you
    need some info on formulas please look on the "Brain dump" provided by Scott
    Arvin in the thread: "where is property ductobject:size defined?" in this
    forum.
    If you need some additional help, please post your
    drawing with your tries, in the customer files area with some comments on what
    you would like it to do and I'll have a look at it.
    /Hakan
    I
    easier way?
    Re:
    11-19-2003 10:00 PM in reply to: DBares
    Hi again,
    I discovered some problems with this now too, if
    you use nominal diameter it provides you with the 1'-3 1/2" format. I
    see two problems with that:
    Problem 1. Formulas doesn't seem to like the "
    much... I got around that problem by assigning the value to a variable like
    this: varName = "[Nominaldiameter] (notice only one ") the value for the var
    name is now 1'-3 1/2.
    Problem 2.
    Hard to calculate with this format... I think I
    soved this by changing the string a bit:
    I came up with the following:
    (Where you should be able to just change the
    conditions of the if things at the button to get your costs.) (I'm attaching a
    dwg wit this and another propset)
    strInch = "
    size=2>[NominalDiameter]
    pos1 = InStr(1, strInch, "'")
    If pos1 <> 0 Then
    feet = CDbl(Left(strInch, pos1 - 1))
    Else
    feet = 0
    pos1 = 1
    pos2 = InStr(1, strInch, "-")
    pos3 = InStr(1, strInch, " ")
    pos4 = InStr(1, strInch, "/")
    If pos4 <> 0 Then
    inch21 = (Mid(strInch, pos3 + 1, pos4 - (pos3 +
    1)))
    inch22 = (Right(strInch, Len(strInch) -
    pos4))
    inch2 = CDbl(inch21) / CDbl(inch22)
    Else
    inch2 = 0
    If pos3 = 0 And pos4 <> 0 Then
    inch1 = 0
    Else
    If pos3 = 0 Then pos3 = Len(strInch) +
    1
    inch1 = (Mid(strInch, pos2 + 1, pos3 - (pos2 +
    1)))
    diam = feet * 12 + inch1 + inch2
    if diam >=10 then
    RESULT = 20*
    size=2>[Length]
    elseif diam >=5 then
    RESULT = 15*
    size=2>[Length]
    else
    RESULT = 10*
    size=2>[Length]
    end if
    hth
    /Hakan
    Hi DBares!
    forum.
    your drawing with your tries, in the customer files area with some comments on
    what you would like it to do and I'll have a look at it.
    /Hakan
    I
    easier way?
