• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Member
    eze_90
    Pipes and fittings in inches
    660 Views, 3 Replies
    12-11-2010 11:56 AM
    I need to use the drawing in mm but the diameter of the pipes and fittings in inches. More than anything I need be able to insert the pipe diameter in the palettes in inches. Any help will be apreciated!
    Please use plain text.
    Product Support
    Re: Pipes and fittings in inches
    12-14-2010 12:20 PM in reply to: eze_90
    When you install AutoCAD MEP, by default it places 3 icons on your desktop.  US Imperial, US Metric and Global Metric.  The US Metric has pipes, duct, equipment made to Imperial dimensions, but shown in metric units.  For example, you may buy a Carrier rooftop unit.  It is made here in America and to dimensions in inches and feet.  The length of the part stays the same in AutoCAD MEP, but the dimensions are shown in metric.  That's what US Metric does.  So use that profile, the names will still be in metric, so you may need to mentally convert it to Imperial.
    Hope this helps.  Merry Christmas.
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Member
    eze_90
    12-15-2010 09:34 AM in reply to: eze_90
    Not worked, US metric has the pipes in mm. It worked when I changed the units to the US imperial but not very good, it removed some diameters from the list. I mean, with the same material and system, etc, in inches it allowed me to put 3" diameter tube, but now it only allows me to use 2 1/2" and 4", not 3". Any ideas? I have seen that changing the catalog path may be a solution. Do I need to make anything special to change the catalogs that is using?
    Thanks again!
    Active Contributor
    01-19-2011 12:24 PM in reply to: eze_90
    what routing preference are you using ?
    Leslie
