• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Member
    Open Drawing Error
    125 Views, 3 Replies
    02-20-2012 04:16 PM
    I intermittently get the following error when opening or checking out drawings from the Vault. Anyone know what is causing this problem? Could it be a setting within Vault or possibly a software installation issue? I am running MEP 2012 Thanks in advance, Earl
    Valued Contributor
    Re: Open Drawing Error
    02-23-2012 05:46 AM in reply to: dimasilang
    I know this is not addressing your question, but , I was curious about using Vault with ACAD MEP. We are a 80 person MEP consulting firm and I was looking to hear your thoughts on Vault and what added value it brings. Are you using the base version of Vault? Are you using Project Navigator for your projects.
    Any insight would be very helpful and much appreciated.
    Bob
    Active Member
    03-01-2012 05:27 PM in reply to: RAMasterson
    Vault is a useful tool for managing a directory of drawings. Vault has search tools similar to Microsoft Access. You can determine the status of drawings with a few simple clicks. You can setup multiple projects within Vault to make it easier for multiple users to share and access information.  This eliminates the problem of over-riding another person’s work.  We are using the basic version of Vault included with Autodesk 2012 suite.
    Hope this helps,
    Earl
    Valued Contributor
    03-02-2012 05:52 AM in reply to: dimasilang
    Thanks for the thoughts Earl. I think I will further investigate using Vault here.
