• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Distinguished Contributor
    Mvpart selection default folder settings?
    156 Views, 3 Replies
    07-10-2003 11:13 PM
    Everytime I try and add a new Mvpart to my drawing the selection defaults to an air curtain. I then have to traverse back through all the folders to get down to a VAV folder. I add a VAV box to my drawing. I select the add Mvpart again, the selection is back again to the air curtain selection. I again have to traverse back through all the menus back down to the VAV boxes. Doing this time and time again gets to be a PAIN! Is there a way to stop the Mvpart catalog from defaulting to air curtains and revert back to the last part added folder??
    Please use plain text.
    Valued Contributor
    Re: Mvpart selection default folder settings?
    07-10-2003 11:35 PM in reply to: jmcfaddn
    good question... I've had the same problem.
    *[Autodesk], Lars-Ake Johansson
    Hi Jody,
    The MvPart Add dialog should by default open up on
    the last part used exepti in one case; If you choose 'Add Mechanical Equipment'
    from the tool palette.
    You can change tis behaviuer if you want by
    changing the command on that tool.
    1. Right click on the icon and choose
    Properties...
    2. Click on the command text
    3. Change the command to ^C^C(command "_MvPartAdd"
    "t" "All")
    Hope this helps
    Lars-Ake Johansson
    Autodesk BSD QA
    Everytime
    folder??
    *[Autodesk], jason martin
    Re:
    07-11-2003 12:31 AM in reply to: jmcfaddn
    Or you can just copy (or use) the add equipment tool from the MEP palette
    Add Mechanical equipment puts you back at the top of the mechanical list.
    Add Terminal puts you back at the top of the terminal list
    Add Fan puts you back at the top of the fan list
    Add equipment puts you back where you were.
    hth
    jason
    "Lars-Ake Johansson [Autodesk]" wrote in
    message news:B5FE0DDE9028599B1ED03AFDBDCCCBA9@in.WebX.maYIadrTaRb...
    > Hi Jody,
    > The MvPart Add dialog should by default open up on the last part used
    exepti in one case; If you choose 'Add Mechanical Equipment' from the tool
    palette.
    > You can change tis behaviuer if you want by changing the command on that
    tool.
    > 1. Right click on the icon and choose Properties...
    > 3. Change the command to ^C^C(command "_MvPartAdd" "t" "All")
    > Hope this helps
    > Lars-Ake Johansson
    > Autodesk BSD QA
    > "jmcfaddn" wrote in message
    news:f176a37.-1@WebX.maYIadrTaRb...
