• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    MvPart connections
    246 Views, 2 Replies
    12-23-2005 10:59 AM
    When using the Multiview Part Convert Tool, I add the connections to the part I am designing. When I tried to change a connection diameter (i.e. for a pipe connection) the connection editor refuses to take the new measurement and defaults back to the original value (1"). Going under the connection "Properties" and changing it there doesn't work either. Does anyone have any idea what I might be doing wrong?
    Please use plain text.
    Re: MvPart connections
    09-18-2012 11:26 AM in reply to: stilesrd99
    I apologize in advance. I don't have a solution to this dilema. I've been waiting for someone with more MEP knowledge to reply. Since this posting, did you figure this out? If so, can you enlighten me?
    Steve
    Active Contributor
    dallasn
    09-26-2012 03:37 PM in reply to: stilesrd99
    I find that if you include the inches symbol ( " ), then the entry will get rejected.
    Try entering just the number?
