• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD MEP
    Distinguished Contributor
    MVpart color not coming in as assigned?
    115 Views, 3 Replies
    07-18-2003 04:23 AM
    I've created a new part. The original block color & line type were assigned BY BLOCK, the line weight is BY LAYER.
    However when I insert the new MVpart it comes in "White". I check the properties which shows, the part to be on the correct layer with the layer color red. Yes, I have created other parts with no problem. Is there a cause for this problem?
    Please use plain text.
    Valued Contributor
    Re: MVpart color not coming in as assigned?
    07-18-2003 05:42 AM in reply to: jmcfaddn
    this might sound dumb, but in the part file.. is the part on layer 0? that could effect it I suppose. Also... if you post it to customer files... I'll take a look at it over the weekend.
    Re:
    07-20-2003 11:50 PM in reply to: jmcfaddn
    Appears to be something with the display settings and overides. Everything is coming in white now, for some reason.
    Re:
    07-21-2003 01:46 AM in reply to: jmcfaddn
    Turns out my new element drawing color setting somehow got changed to BYBLOCK. How that happened I don't know. Once it was changed to BYLAYER everything started coming fine. Now I have to try to remember all the display settings changes I made trying to troubleshoot this thing.
