AutoCAD MEP
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
MEP object properties vs. Autocad object properties 911!!!
Options
- Highlight
- Email to a Friend
255 Views, 7 Replies
06-26-2009 07:21 AM
When I select an MEP object my properties palette displays the propeties of that object.
When I select an AutoCAD object (LINE, ARC, RECTANGLE, PLINE, CIRCLE,) the properties palette is blank. No properites can be viewed, or edited.
Any suggestions???
Any suggestions???
Re: MEP object properties vs. Autocad object properties 911!!!
Options
- Highlight
- Email to a Friend
06-26-2009 09:49 AM in reply to:
pauros_78
No Suggestions.... but what version of MEP are you using?
Options
- Highlight
- Email to a Friend
06-26-2009 09:59 AM in reply to:
pauros_78
I am running MEP 2009
Options
- Highlight
- Email to a Friend
06-26-2009 10:44 AM in reply to:
pauros_78
You've shut down..... restarted.... We've found that "fixes" all kinds of weirdness in 2009... temporarily anyway.
Options
- Highlight
- Email to a Friend
08-27-2009 10:28 AM in reply to:
pauros_78
I have something similar with MEP 2009 and MEP 2010. This glitch appears to only happen with the object snaps toolbar. I've attached a screenshot of what is happening. This is running Windows 7 64bit (happened same with Vista 64bit, so it's not a Windows 7 issue).
The mep object snaps appear to be overlaying themselves instead of having two columns.
Options
- Highlight
- Email to a Friend
09-01-2009 06:46 AM in reply to:
pauros_78
"... No properties can be viewed, or edited."
Can you post a screen shot please?
We are having similar issue... we have NavisWorks 2010 loaded with AutoCAD MEP 2009... when a viewport is selected properties paletteis blank, no editboxes, no labels... just blank.
We've done a repair install and the problem clears up... but then NWNavigator in AutoCAD is broke... we fix NWNavigator and then properties palette is blank again.
Options
- Highlight
- Email to a Friend
09-01-2009 07:48 PM in reply to:
pauros_78
I am not working with the company where I was having this problem any more.
I am now working with a new company so I am not able to post a screen shot, however....
The properties palette was not "blank" but appeared with no text in the fields of the palette.
Normally you would see "no selection" or "line" or whatever you had selected when you open the palette in the top pull down but this was blank or almost "bald" looking because there was no text but it looked funny
This would have been fixed if I could have repaired or reinstalled, but I never had that done to see if it would work.
I was interested in seeing the post about NWNAVAGATOR....it definitely acts weird in '09 I remember after I had opened it once, even if I closed it and never opened it again during my ACAD session, closed and saved.... it would open when I restarted the following day.
I would not want that to stay open and tried to force it to "stay away" or stay closed, by closing it and saving the workspace but it still opened upon a restart.
Good times......
Thanks for the posts....
-Paul
Good times......
-Paul
Options
- Highlight
- Email to a Friend
09-01-2009 08:01 PM in reply to:
pauros_78
oh yeah and Terryd....
I have the same problem with MEP2010 on a machine that is running Windows 7 64 bit...
wierd glitch
wierd glitch
