• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Member
    gettyprojector
    MEP distance constraints
    186 Views, 2 Replies
    10-31-2012 08:47 AM
    Hi, I've been given a DWG that I need to use for my project. Unfortunately, the object is very, very far away from the origin. I've thought of two ways to solve this but I can't seem to figure it out.
    1. Move the objects to the origin.
    2. Reset the origin to where the objects are.
    Option 1 seemed easy enough, but I needed to move the objects about 8,000,000'. That's not a typo. 8 million feet. I use the move function, but then it always puts me at a weird distance. Is there a constraint on how far you can move objects? For example, I would move the object 8m feet, but then I would measure it out with 'distance' to be at 6m feet. It always gives me a different value.
    I do not know how to go about proceeding option 2.
    Please help!!
    Please use plain text.
    Keith.Brown
    Re: MEP distance constraints
    10-31-2012 02:05 PM in reply to: gettyprojector
    You can copy the item using the insertion point as the basepoint and then paste it at 0,0,0.  Then you can delete the original item.  Use the clipboard copy and not the copy command.
    Keith Brown AutoCAD MEP BLOG | RSS Feed
    Member
    gettyprojector
    10-31-2012 02:42 PM in reply to: Keith.Brown
    You are talking about ctrl+c and ctrl+v? That way doesn't allow you to choose a base point, but the 'copy' function doesn't allow you to specify coordinates for base points. Is there another copy and paste you are referring to?
