• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Contributor
    MEP 2013 No MVParts Catalog Interface
    220 Views, 6 Replies
    08-23-2012 12:41 PM
     When I try to select equipment, instead of a window displaying all the different mvparts, i just get a diffuser to place.  Why is my catalog not displaying?
    Please use plain text.
    *Expert Elite*
    Keith.Brown
    Re: MEP 2013 No MVParts Catalog Interface
    08-23-2012 12:44 PM in reply to: Smitkins
    make sure your not running the command -mvpartsadd which is different than the command mvpartsadd.  They Hyphen supresses the dialog box.  You can look at the command line to see which command was actually ran if you are accessing it from a ribbon, toolbar, or palette button.
    Keith Brown AutoCAD MEP BLOG | RSS Feed
    Active Contributor
    08-23-2012 01:07 PM in reply to: Keith.Brown
    Attached is my command prompt contents.  Even when i type the command in directly, i get the same result.
    *Expert Elite*
    Keith.Brown
    08-23-2012 01:13 PM in reply to: Smitkins
    It looks like the command is correct.  It is just filtering the mechanical chapter so you won't see any of the electrical or plumbing content.  Have you checked that the dialog is not offscreen somewhere?  Are you running two monitors?  Have you moved it off to the side and then forgotten about it?  I would check all of those things.
    Active Contributor
    08-23-2012 01:22 PM in reply to: Keith.Brown
    I looked all over and still can't find it.  If I use the Global profile it works fine.  I'm using Imperial.
    Active Contributor
    08-23-2012 01:31 PM in reply to: Keith.Brown
    I opened up several different profiles and then went back to the Imperial profile that I was using and it works now.  I wish I could say that I figured it out, but I don't have a clue as to why how it was fixed.  Thanks for your input Keith!
    *Expert Elite*
    Keith.Brown
    08-23-2012 01:34 PM in reply to: Smitkins
    My guess is that it was hiding offscreen.  Switching profiles is a trick I use to bring back palettes that have gone hiding on me.  I guess it works for dialog boxes also.  Glad to hear that you got it working.
