• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Contributor
    Accepted Solution
    MEP 2012 PickFirst not working
    697 Views, 7 Replies
    01-17-2012 10:46 AM
    I thought the pick first command was fixed with the SP1 for MEP 2012, but lately it isn't working.  I am unable to select objects before issuing commands, it just bounces me out of the selection if I try to use a command after picking objects.  Is there a reason for this?  My variable is set correctly but it doesn't work.  This is a real problem for us.
    Please use plain text.
    Valued Contributor
    Re: MEP 2012 PickFirst not working
    01-17-2012 01:57 PM in reply to: mlmoore
    Check QAFLAGS is set to 0.
    QAFLAGS been used a long time (<r12) by developers and autodesk themself too.
    QAFLAGS acceps a value between 0 and 32767
    bit 0 (1) : ^C in menu macro cancels grips (acts like keyboard <Esc>).
    bit 1 (2) : no pause during text screen listings.
    bit 2 (4) : no "alert" dialogs (text display instead).
    bit 7 (128) : accepts "screen picks" (point lists) via (command) function.
    Normally QAFLAGS should be set to 0.
    Active Contributor
    01-17-2012 02:19 PM in reply to: mlmoore
    qaflags did the trick, thank you very much, I have no idea how they ended up changing, but I'm back to being a happy camper again.  THANKS!!!
    Active Member
    04-21-2012 10:20 PM in reply to: mlmoore
    I tried this for me and it did not work, by QAFLAGS is set to 0.
    Just wantd to clarify, when you are saying "PickFirst," you are referring to selecting lines/object and then typing into the command line a command to manipulate the elements, correct? Because every time I try selecting lines or something to erase, copy, move BEFORE typing in the command, it does not work.
    Active Contributor
    04-23-2012 06:51 AM in reply to: el.nygaard
    Yes, that is correct, when I clicked on something first then tried to issue a command it would knock me out of the pick.  The qFlags did fix things for me so I'm not sure what may be your issue.  I'm guessing you made sure your toggle value in the properties manager is set correctly, but that is the only other thing I can think it might be.  Hopefully someone with more knowledge will be able to shed additional light on this issue.
    Active Member
    04-23-2012 10:02 AM in reply to: mlmoore
    I found my answer over here:
    http://forums.autodesk.com/t5/AutoCAD-MEP/Delete-Button-Not-Working/m-p/3048266/highlight/true#M2915...
    "Check that your "pickfirst" variable is set to "1". It does change sometimes for no reason on my machine."
    "Pickfirst" solved it.
    New Member
    ChrisFullmer
    07-17-2012 09:42 AM in reply to: jcleghorn
    QAFLAGS = 0 worked for me!
    I've been dealing with this for months!  (I'm not an every day CAD user though).  I kept looking around and never found anything other than the pickfirst variable.  I'm so glad you posted this fix.  BTW, I'm running Map 3D 2012.
    New Member
    01-30-2013 10:50 PM in reply to: jcleghorn
    It has been driving me nuts for the last two days, I've been searching pickfirst solutions, but the QAFLAGS did the trick! Mine was set to 5. I'm running Map3d 2011.
    Cheers,
    Wendy
