AutoCAD MEP
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Louver Selection
Options
- Highlight
- Email to a Friend
113 Views, 5 Replies
06-06-2003 05:28 AM
I need to add a variety of louvers in wall openings that have been provided by the Architect (AD2004). I see I only have one choice (24"X24"). I have tried to make changes to the height and width factors but the louver never changes from a 24"x24"....How do I add sizes to this list?
PLEASE HELP ME ASAP.......PLEASE!
Thank you,
Aaron
Thank you,
Aaron
Aaron A. Gray
Advance Design
369 Sagamore Drive
Rochester, NY 14617
585-734-8277
Advance Design
369 Sagamore Drive
Rochester, NY 14617
585-734-8277
Re: Louver Selection
Options
- Highlight
- Email to a Friend
06-06-2003 06:36 AM in reply to:
advandes
Good luck buddy! For $5,000 that's all you get, 1 selection. You have to do the rest on your own. I spent 2.5 days trying to modify one to another size, finally gave up. I've been saying this all along, this software is not of much use without a good library or one you can easily add to. Autodesk will probably offer an expanded library CD at an additional cost of $1,000 or so. Get your checkbook ready.
Jmcfaddn
Jmcfaddn
Options
- Highlight
- Email to a Friend
06-10-2003 04:06 AM in reply to:
advandes
Aaron,
Were you able to modify and recreate various sized louvers based on Hakan response. Yeh, once you have the resized block it's easy to recreate the MvPart. It's modifying the block that is the difficult part. I tried to modify a sidewall supply grille, the thing had 50-60 pieces in it, which made it very difficult to resize.
Let me know if you had any luck.
Jmcfaddn
Jmcfaddn
Re:
Options
- Highlight
- Email to a Friend
06-12-2003 01:24 AM in reply to:
advandes
The directions given by Hakan did not work, and if they did, I'd have to say that would be a pain to have to create even a half dozen sizes of louvers. Haken, would please follow your own directions and see if maybe you forgot a step or two. Please let me know! Aaron
Aaron A. Gray
Advance Design
369 Sagamore Drive
Rochester, NY 14617
585-734-8277
Advance Design
369 Sagamore Drive
Rochester, NY 14617
585-734-8277
Re:
Options
- Highlight
- Email to a Friend
06-13-2003 12:49 AM in reply to:
advandes
Aaron,
I followed the same direction and it worked fine
*[Autodesk], Hakan Wikemar
Options
- Highlight
- Email to a Friend
12-14-2003 12:05 AM in reply to:
advandes
Hi Aaron
I'll try to give you a such a detailed procedure as
possible (hence the text mass) faster procedure when you get the hang of
it.
it.
To add sizes to the list, the first thing you will
have to do is to go into the Louver dwg and create the modelblocks for your new
sizes:
sizes:
(by default located in the directory: C:\Program
Files\Autodesk Building Systems 3\AECB Catalogs 3\MvParts US
Imperial\Mechanical\Louvers\)
The easiest way to do this is usually to insert the
existing model block and modify this (I tried this on the Extruded one so my
example derives from that one)
I tried to create a 12x12 one
1. First insert the Extruded Louver Model (in
0,0), use "scale" on it 0,0 0.5, then explode the block and then create a
new block named 12x12 Extruded Louver Model and save and exited the
dwg.
dwg.
2. Now start the contentbuilder navigate down to
Extruded Louver in Mechanical and push the add part size button.
3. Check type and Subtype (should be ok) - next -
add partsize (Small button below scrollbar) - a dropdown should appear choose
our new block 12x12..... and click somwhere else.
Now the other views should be filled but
some of them should be colored red (not created yet) You could if you
wanted to create all theese views separetly in the dwg but we will create
them automatically. You can also define a symbolblock if you want
too.
too.
4. Hit Generate Blocks - popup - hit ok -
next
next
5. Choose BMP (Use the one allredy defined we don't
need a new one for this) - next
6. Go down to Connector 1 on 12x12 and right click
- edit connector
- edit connector
7. Your block should now appear with a missdirected
red connector icon in the center now "all" we have to do is to specify the
Properties of the Connector
Connection type: Change to Slip Joint
Position: Change to 0,1.625,0
Normal: 0,1,0
Rotation: OK (0)
Width: 12
Height: 12
OK
Next
Finish
Now run a catalogregen on MvParts and the new part
should be available.
Hth
Let me know if you run in to any trouble on the
way.
way.
/Hakan
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"advandes" <I
href="mailto:agray2@rochester.rr.com">agray2@rochester.rr.com> wrote in
message
href="news:f16b73b.-1@WebX.maYIadrTaRb">news:f16b73b.-1@WebX.maYIadrTaRb...
Thank you,
Aaron
