• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    Label / Size of Flexible duct not showing up
    226 Views, 1 Replies
    11-29-2011 12:43 PM
    I’m currently using AutoCAD MEP 2012 and I am having problems
    With the label of the flexible duct not showing up.
    I selected the label of the rectangular duct and right clicked the add selected
    Then select the flexible duct. The label shows up when I pick the flexible duct but
    Disappears when I click to locate it or put it.
    I will appreciate any advice you can give me to solve this problem.
    Please use plain text.
    Active Contributor
    Re: Label / Size of Flexible duct not showing up
    12-06-2011 06:03 AM in reply to: ftplm1988
    What label are you using?  Did you create it or is it out of the box?  If it is a label you created have you tried going back and using one of the delivered duct labels?  Is it just the size label or if you use the system one is it doing the same thing?
     Have you tried starting a new file and do you get the same result?  I can take a look if you post a sample file with the issue.  I would also check and make sure you are not in a shaded vport mode, have layer 0 turned off those types of things.
