• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Valued Contributor
    smbrennan85
    Accepted Solution
    Just received APJ file
    417 Views, 5 Replies
    11-19-2012 12:22 PM
    I am in the process of exploring more effecient ways to work as an electrical contractor. I recently started working on a design-build job, and the CAD files were obviously done using Project Navigator (PN). The ZIP folder contained views, constructs, sheets, etc.  However, it did not come with the .APJ file. When I requested the file, I got it no problem. However, now that I have it, I apparently have no idea on how to link the files I have to the project file. When I open the Windows Explorer location through PN, it brings me to the correct location and I see the files in Windows, but not in PN.
    Am I doing something wrong? I'm sure I missed a step somewhere, but I just can't seem to figure it out.
    Please use plain text.
    *Expert Elite*
    Keith.Brown
    Re: Just received APJ file
    11-19-2012 12:27 PM in reply to: smbrennan85
    In order to have the dwg files show up in the project navigator you need to have the individual xml files for EACH dwg.  This is how the PN knows that a file belongs in the project.  You can either request all of the files or open up in file and save it into your project.  If you do not have many files then this is probably the fastest way to go.  If you have alot of files then you should request that the file owners also send the xml files with the dwg files.
    Keith Brown AutoCAD MEP BLOG | RSS Feed
    Valued Contributor
    smbrennan85
    11-19-2012 12:36 PM in reply to: Keith.Brown
    Thanks for the quick reply.
    I believe I tried that by doing the following:
    • Open a drawing (from the Constructs)
    • In PN, right click Constructs and select "Save Current DWG as Construct"
    • When prompted at the Add Construct file, I don't make any changes to the Name, Desc, or Category. I check the box for the only division available (4th Floor, as this is a single floor tenant build-out).
    • When I click OK, I get a message saying "A file with this name already exists in this category. Please enter a different name."
    I understand what it's saying, but is there a way to remove the previous link, or to override that link with the new file?
    *Expert Elite*
    Keith.Brown
    11-19-2012 12:43 PM in reply to: smbrennan85
    I should have mentioned that before,  You will have to move the file out of the directory before trying to add it or you will need to rename it.  Another option is to create a blank file and add it to the project.  Then open up its xml file and note how it is made including the naming for the division, level, etc.  You can then just rename the name of the xml file and add it to the same directory as the original dwg.  It will then add the file to the project.  The xml file should look something like this.
    <?xml version="1.0" encoding="UTF-8"?>
    <File Name="V-CN-L01-SUSPENDED (US Metric)">
        <Version>70</Version>
        <Description>V-CN-L01-SUSPENDED (US Metric)</Description>
        <Region>
            <Cell Level="1" Division="1"/>
        </Region>
    </File>
    I don't usually recommend mucking around with xml files manually but these are simple to create and if you mess one up it won't have any adverse affect on your model other than placing it at the wrong elevation.
    Good Luck!
    P.S.  I created that out of Autocad MEP 2013.  You should create one using your software and mimic the version number from your software instead of using the one I showed.
    Valued Contributor
    smbrennan85
    11-19-2012 12:47 PM in reply to: Keith.Brown
    Ahh, that helps it make sense.
    So the EASIEST way to do this, regardless of how big or small the job is, would be to obtain these XML files from the creator of the APJ file?
    The next best option is to remove any constructs, views, sheets, etc from their respective folder, then add it back in manually.
    *Expert Elite*
    Keith.Brown
    11-19-2012 02:48 PM in reply to: smbrennan85
    Yes,  the easiest way would be to obtain all of the files from the owner of the project.
