• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    atinbender
    Just getting started with MEP 2011, looking for a push in the right direction.
    293 Views, 3 Replies
    09-15-2011 12:38 PM
    I'm just getting started with MEP 2011, I work in the HVAC Trade (Duct). I have found myself needing to get up to speed quickly! I would appreciate any suggestions on how best to get started with tutorials, videos, etc. I have some experience with AutoCAD and a much older version of MEP. This is totally different! A push in the right direction would be appreciated.
    Thanks, atinbender
    Maurice Ramsey Sr.
    Please use plain text.
    Active Contributor
    Re: Just getting started with MEP 2011, looking for a push in the right directio
    09-15-2011 02:50 PM in reply to: atinbender
    As you said Tutorials, it will teach you how to use the tools to get the job done. Anythings else you have to explore.
    Leslie
    Member
    cadludde
    12-07-2011 05:47 AM in reply to: atinbender
    Apart from the numerous Youtube videos out there, I find Paul F Aubins books very useful!
    Take time to set up your template file and standards properly from start, it will speed up the learning process a lot!
    /Patrik
    Product Support
    12-12-2011 01:30 AM in reply to: cadludde
    You could also check the below links which could give you a first-hand push to AutoCAD MEP.
    User's Guide
    http://images.autodesk.com/adsk/files/autocad_mep_user_guide_english.pdf
    Skill Builders
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=12785549&linkID=9240935
    Tutorials
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=9493064&linkID=9240935
    There are also a lot of videos posted on YouTube which you could check.
    http://www.youtube.com/results?search_query=autocad+mep+2011+tutorial&oq=AutoCAD+MEP+&aq=2&aqi=g10&a...
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Shiny Stephen
    Support Specialist
    Product Support
