• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Distinguished Contributor
    Is there a way to put the UCS Icon in the right corner?
    250 Views, 3 Replies
    07-06-2003 11:26 PM
    My pallets tend to block the UCS Icon. Is there a way to move the UCS Icon to the bottom right corner instead of the bottom left?
    Please use plain text.
    *Liang, Qi
    Re: Is there a way to put the UCS Icon in the right corner?
    07-06-2003 11:50 PM in reply to: jmcfaddn
    The other way to solve the problem is setting the
    pallets 'Transparency'.
    Right click the pallet title bar \ Transparency...\
    drag the scroll bar to More \ OK.
    Thanks.
    Qi Liang
    My
    Re:
    07-07-2003 12:02 AM in reply to: jmcfaddn
    Nice thought, but not practical. With a black background and my toolbars over there along with the drawing elements, if you modify the pallet's transparency you cannot see the utilities on the pallet to be able to distinguish them.
    Valued Contributor
    Re:
    07-07-2003 04:46 AM in reply to: jmcfaddn
    You can set the UCS origin to someplace other than 0,0 and turn on the setting for "Display at UCS origin point", the problem being that as soon as you zoomed into an area that didn't include your new UCS origin point it would default back to where it currently is that you are trying to move it away from. -- a neat fix for you i suppose would be a little lisp routine that would look at your current view and locate the lower right point and reset the ucs origin to that... or that minus some distance in the X plus some distance in the Y that would allow the ucs to sit in your lower right. of course each time you changed your zoom you would have to have an icon that you could click to activate that, it's probably even easy to write. -- ultimately it would be best if Autodesk would just let us choose to have it display in an alternative location than where it currently lives by default. -- and one final note... I work in model space and I have it divided into two vertical viewports... I have one pallet located just right of the left edge of my screen, one just left of the right edge of my screen, and one just right of the line that separates the two viewports. I have the auto-hide on and the transparency at 50%. I too use a black background and this seems to be working well for me. I also don't use any side toolbars and the scroll bars aren't displayed... I like drawing area real estate. -- that's the best I can offer.
