• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *Services, Tony - Autodesk Professional
    Interim fix available for MAX and DRF file corruption caused by recent Micros
    41 Views, 0 Replies
    08-05-2003 06:17 AM
    Here is the latest information that
    is available regarding the MAX and DRF file corruption issue.
    Tony Michniewicz
    Services
    ISSUE
    Autodesk® has confirmed that Microsoft® Hotfix
    823980, which is contained in the Windows® 2000 Service Pack 4, causes the
    corruption of MAX and DRF files resulting in the inability to open MAX or DRF
    files that were saved after either of these Microsoft Windows Updates had been
    installed.
    The following Autodesk products are affected by
    this issue:
    Autodesk® Architectural Desktop 2004
    Autodesk® Building
    Systems 2004
    Autodesk® VIZ 4
    3D Studio VIZ® R3i
    3D Studio VIZ®
    R3
    The following operating system configurations
    will experience MAX and DRF file corruption:
    Windows 2000 Service Pack 4
    Pack 3 or lower + Microsoft Hotfix 823980
    Windows XP Professional + Microsoft
    Hotfix 823980
    Windows XP Home Edition + Microsoft Hotfix 823980
    Note:  It was previously
    reported that this problem affected Windows NT 4.0 Service Pack 6 but further
    testing confirmed that this issue does not affect users Windows NT
    4.0.
    SOLUTION
    For those of you who have updated to Microsoft®
    Hotfix 823980 or Windows 2000® Service Pack 4, Microsoft has developed an
    early-version Hotfix to resolve this issue.  To acquire the early-version
    Microsoft® Hotfix, you can contact Microsoft at 800-936-4900 and request “Hotfix
    - Q824136 for Windows 2000 or Windows XP.”  You will be asked to provide
    your name, e-mail address and zip code after which an approximately one Mb file
    will be sent to your e-mail address.  The early-version Microsoft® Hotfix
    will only install if you have previously installed Microsoft® Hotfix 823980 or
    Windows 2000® Service Pack 4.
    Note:  The early-version
    Microsoft® Hotfix is for English language versions only.  If you are
    working with other language versions and encounter this problem, you should
    follow the temporary instructions included below:
    Temporary Instructions for Microsoft
    Windows Hotfix 823980 Configurations
    If you have installed the
    Microsoft Windows Hotfix 823980, Autodesk recommends that you uninstall this
    Hotfix, which will allow existing or recently saved/corrupted MAX and DRF files
    to be opened without any errors.
    To determine if you have installed the Microsoft Windows Hotfix 823980,
    access your Add/Remove Programs dialog box from the Windows Control Panel.
    If this Hotfix has been installed, there will be an entry with a title similar
    to "Windows Hotfix 823980".  To uninstall this Hotfix, select the "Windows
    Hotfix 823980" entry and click Remove.
    Note:  It is highly recommended that you back-up
    any critical data before uninstalling Microsoft Windows Hotfix 823980.
    Important:  In all cases, you should disable
    automatic windows updates through WinUpdate to eliminate the possibility of
    inadvertently reinstalling the Microsoft Windows Hotfix 823980 before the new
    Microsoft Windows Hotfix becomes available.
    Temporary Instructions for Windows 2000 Service Pack 4
    Configurations
    Method #1
    1. Uninstall the Windows 2000 Service
    Pack 4.
    2. Use the Merge command, located on the File menu, to
    retrieve data from the corrupted MAX or DRF files and then save the
    files.
    Note: If you have Render Effects or Atmospherics in your
    MAX or DRF file, use the Merge button in the respective dialog
    boxes.
    Important: Some data may be lost if you use this method
    to work around this issue and Autodesk recommends that you retain original
    copies of any corrupted MAX or DRF files until a final resolution to this
    issue is identified.
    Method #2
    Pack 4.
    2. Open the corrupted MAX or DRF files from a Windows XP
    system that does not have the Microsoft Windows Hotfix 823980 installed.
    3. Save the files and return the files to the system on which the
    Windows 2000 Service Pack 4 has been uninstalled.
    Note: It is highly recommended that you back-up any
    critical data before uninstalling the Windows 2000 Service Pack
    4.
    Please use plain text.
