• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Contributor
    Import / Export Tool Palettes
    2152 Views, 5 Replies
    11-03-2011 12:34 PM
    I am using MEP 2012 and trying to export my customized tool palette, so I could share the palette with other CAD users on a server. I am following Autodesk Exchange instruction on Import / Export Tool Palettes. Please refer to the attached picture for the insturction.
    The problem is that I can't find the following options anywhere on my MEP 2012 CAD. I checked my coworker's CAD just in case I was missing anything, but he had the same issue.
    Export a tool palette
    Export a tool palette group
    If this is not the right way of sharing tool palettes with others on a server, what is the right way?
    TTW
    Please use plain text.
    Active Contributor
    Re: Import / Export Tool Palettes
    11-04-2011 07:00 AM in reply to: TravelTheWorld
    Never mind. I have solved it myself.
    :smileywink:
    Valued Contributor
    tkendrick
    12-21-2011 07:19 AM in reply to: TravelTheWorld
    I have the same problem. Could you explain how you solved it?
    Use this link to tell Autodesk about features you need:
    Active Contributor
    12-27-2011 07:00 AM in reply to: TravelTheWorld
    I was told that import/export tool palette using Tool Palettes Customization does not work any more. So, I used Content Browser instead to export all my tool palettes as a library on a server, and the other users drag the library to their tool palettes to import. Does it make sense?
    Feel free to shoot an email if you have more questions.
    New Member
    gtmotm
    03-08-2012 06:45 AM in reply to: TravelTheWorld
    i am having the same problem.  could you provide some advice?  when i open contents explorer, it does list my palettes. i also am using mechanical 2012....  thnaks!!
    when i open my palette on my other computer, it doesn't show any of the icons......
    tom
    Active Contributor
    07-02-2012 08:55 AM in reply to: gtmotm
    Similar problem.
    I am using MEP 2012.
    Help!
