• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Distinguished Contributor
    How to make a 3d Surface/Mesh?
    466 Views, 3 Replies
    06-30-2003 12:31 AM
    I see the solids menu, but do not see where to make a 3d surface or Mesh as described in the ACAD help file?
    Please use plain text.
    *Andrew
    Re: How to make a 3d Surface/Mesh?
    06-30-2003 01:07 AM in reply to: jmcfaddn
    You will need to load the standard acad menu.
    Or copy that part of the acad menu into your BS menu.  Or you can type in
    the commands.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I
    Re:
    06-30-2003 02:46 AM in reply to: jmcfaddn
    ?? you'd think there would some menus in Bldg Sys. since we are required to build Mvparts. If I load the ACAD menu, which I've done by mistake already, I lose all of my previous menu settings. Is there a way to draw a solid then explode it to surfaces?
    *[Autodesk], Bo Noren
    Re:
    07-01-2003 12:03 AM in reply to: jmcfaddn
    It is possible to switch to AutoCAD menus by
    selecting Window->Pulldowns->AutoCAD Menus. To switch back select
    Building Systems->Restore Building Systems Menus. As Jody points out you
    will lose your menu settings (toolbar positions e t c) when switching. If
    that is a problem I would suggest using two different profiles; one for
    AutoCAD menus and one for Building Systems menus.
    /Bosse
    it to surfaces?
