• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Distinguished Contributor
    How to determine Duct Label insertion angles?
    74 Views, 1 Replies
    07-22-2003 05:45 AM
    I'm connecting my HVAC diffusers to my duct mains, the duct is placed at random angles along with the duct labels. After the duct and labels are placed, I then rotate and offset the labels to get them back to horizontal and in a location that is readable. Determining the angles to rotate the text back to horizontal is impossible to figure out. Properties does not show anything regarding rotation. How is this suppose to be done?
    Please use plain text.
    *[Autodesk], Bo Noren
    Re: How to determine Duct Label insertion angles?
    08-03-2003 08:13 PM in reply to: jmcfaddn
    Hi Jody,
    You can rotate the Label nodes with the Ucs as
    reference instead of the duct angle. Instead of entering an angle enter U (for
    Ucs) at the command line in the label rotate command.
    You can rotate multiple nodes in one single
    operation. Use for instance Quick Select in the Property Palette to select all
    label nodes and then right click and choose the Rotate Node tool and rotate all
    nodes.
    Hope this helps!
    /Bosse
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">I'm
