• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Contributor
    How do you find an MvPart in a drawing by "handle"?
    138 Views, 3 Replies
    04-30-2012 01:26 PM
    Greetings,
    I'm working in AutoCAD MEP 2011.
    When running a clash detection of a 6-story building in Navisworks (each floor is a separate construct file), I can select an MvPart in the view and get that element's handle (unique identifier).  How can I find that particular part in the construct file, by searching for its handle?
    Is there a lsp routine out there that allows the user to enter a MvPart's handle, and have the program zoom to that part?
    Many thanks,
    Dave
    Please use plain text.
    Active Contributor
    Re: How do you find an MvPart in a drawing by "handle"?
    05-01-2012 06:02 AM in reply to: dbillion
    Dave,
    Try the below
    code:
    (defun C:HANDLE ( / handle ent )
    (setq handle (getstring "\nEnter handle to search for: "))
    (setq ent (handent handle))
    (if ent
    (progn ;line added
    (sssetfirst nil (ssadd ent))
    (command "_zoom" "_Object" ent)
    ;Else
    (ALERT "The handle you entered does not exist in this drawing!")
    (princ)
    (defun OwnerName (handle)
      (cdr (assoc 2 (entget (cdr (assoc 330 (entget (handent handle)))))))
    Active Contributor
    05-01-2012 06:30 AM in reply to: jcampbell
    Works!  Just what I was looking for.  Thanks.
    Active Contributor
    05-01-2012 06:48 AM in reply to: dbillion
    Welcome.  You may want to mark my post as the solution.
