• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD MEP
    Active Contributor
    GIZMO Off
    515 Views, 4 Replies
    01-25-2013 06:54 AM
    Is there any way to permanently and globally turn off the Gizmo? I'm constantly setting DEFAULTGIZMO to 3 in my drawings, but it resets to 1 after reopening the drawing.
    I'm using MEP 2013. Any help is appreciated!
    Please use plain text.
    Product Support
    Re: GIZMO Off
    01-30-2013 12:18 PM in reply to: sixpack_cuda
    See http://screencast.com/t/DJPct3lphz
    Behavior cannot be changed.
    Joshua
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Active Contributor
    Re: GIZMO Off
    01-30-2013 12:22 PM in reply to: sixpack_cuda
    That is, disappointing.  But thanks for your reply.
    Member
    Re: GIZMO Off
    02-02-2013 06:58 AM in reply to: sixpack_cuda
    Just add the following line to your acaddoc.lsp file:
    (setvar "DEFAULTGIZMO" 3)
    If you haven’t already created an acaddoc.lsp file, use notepad to save one in C:\Users\<loginname>\AppData\Roaming\Autodesk\MEP 2012\enu\Support.
    JMV
    Active Contributor
    Re: GIZMO Off
    02-04-2013 06:56 AM in reply to: jvernice
    That worked perfectly, thank you!
