• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Member
    Re: Flattening 3D to 2D
    02-23-2011 07:26 PM in reply to: bytown
    Accessed via the right click menu.
    (Edit: Wooops you're on a mac, hmmm I'm not sure how that works with macs)
    (Edit2: Entering properties in the command line should do it)
    Please use plain text.
    Active Member
    jdd285
    02-23-2011 08:14 PM in reply to: Watershape2
    ok so this is what i have done. i found a friend who has autcad 2008 .. opened the file and command: FLATTEN .... it worked for one file but not the other... I not sure why. any suggestions or anyone willing to try it out? also i would like to find out how to fix this problem without depending on older versions...
    Thanks for all the help.
     lets keep trying
    Distinguished Contributor
    02-23-2011 11:12 PM in reply to: jdd285
    Make sure that the contors you trying to flatten arent locked under your layer manager. I found that to be the case with the file you posted.
    Active Member
    jdd285
    02-23-2011 11:50 PM in reply to: Schmit01
    your correct. the layers were locked however, after unlocking them still could not get it to work.
    New Member
    08-10-2011 11:23 PM in reply to: jdd285
    hey your file need to be unlocked then you can do the flatten
    ok
    08-11-2011 01:22 AM in reply to: raajmath
    Active Contributor
    ben_hmac
    08-11-2011 07:04 AM in reply to: jeff
    try exploding it while you are on the top view.
    Active Contributor
    ben_hmac
    08-12-2011 01:50 AM in reply to: ben_hmac
    what i suggested was only for MEP  3D objects. i saw your uploaded drawing and i would suggest you to make the start/end z elevation equal. i have tried it and it works (see attached). you have to spend some of your time since you cannot select all in one go so you have to select by group or each line.
