AutoCAD MEP
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Flattening 3D to 2D
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Accessed via the right click menu.
(Edit: Wooops you're on a mac, hmmm I'm not sure how that works with macs)
(Edit2: Entering properties in the command line should do it)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
ok so this is what i have done. i found a friend who has autcad 2008 .. opened the file and command: FLATTEN .... it worked for one file but not the other... I not sure why. any suggestions or anyone willing to try it out? also i would like to find out how to fix this problem without depending on older versions...
Thanks for all the help.
lets keep trying
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Make sure that the contors you trying to flatten arent locked under your layer manager. I found that to be the case with the file you posted.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
your correct. the layers were locked however, after unlocking them still could not get it to work.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hey your file need to be unlocked then you can do the flatten
ok
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Once you export them this should work
http://www.theswamp.org/index.php?topic=18153.0
http://www.theswamp.org/index.php?topic=33105.msg3
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
try exploding it while you are on the top view.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
what i suggested was only for MEP 3D objects. i saw your uploaded drawing and i would suggest you to make the start/end z elevation equal. i have tried it and it works (see attached). you have to spend some of your time since you cannot select all in one go so you have to select by group or each line.
