• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Flattening 3D to 2D
    25789 Views, 17 Replies
    05-06-2010 01:17 PM
    I've been trying to "Flatten” a 3D file to make it 2D and reduce the file size. I’ve followed the text instructions word for word but with no success. The pipes change in appearance (Pipes now appear Wire framed) but retain their “Z” coordinate and and still 3D if view isometrically. The size of the file went from 18 meg just to 15 meg.
    Please use plain text.
    Valued Contributor
    Re: Flattening 3D to 2D
    05-06-2010 02:20 PM in reply to: bytown
    export to AutoCAD
    _AecExportToAutoCAD2007
    06-11-2010 12:52 PM in reply to: bytown
    try a AECTOACAD command (look it up if needed) It normaly takes 3d CAD files and flattens them just fine for our company.
    -format
    --2000
    ---suffix = 1
    enter
    enter
    enter
    (it will create a NEW CAD file where ever the current file was located. so just close out of the current file and go to the same folder it was in and you will see a new file with a "1" after it, open it and it should all be flat)
    fyi make sure you are not trying to flatten a block, must BURST it forst.
    hope this works for ya.
    Distinguished Contributor
    06-13-2010 10:22 AM in reply to: bytown
    Also make sure you in your model space and in plan view
    Active Member
    06-13-2010 11:04 AM in reply to: bytown
    The FLATSHOT command is what your looking for, I believe. You have the option to keep hidden lines and put them on a different color and linetype or to leave them off and produce a realistic looking plan view.
    If your using MEP objects they won't flatshot (I believe it's only 3D solids that are captured) so you will have to be in an isometric view and use the CONVERTTO3DSOLIDS command.
    Active Member
    jdd285
    02-22-2011 08:10 PM in reply to: bytown
    ok so im new to autocad. im using a mac. please help. i have a 3d line drawing of a topo. and im trying to flatten it. i have tried  flatshot but does not seem to help. there are not surfaces just lines. i figured this out when measurements were all messed up. i have have been looking at the file from top view not knowing of the 3d component .. any advice.?
    02-22-2011 09:19 PM in reply to: bytown
    You cant use flatshot because they are not 3D objects. Try use the flatten command
    Active Member
    jdd285
    02-22-2011 09:30 PM in reply to: Schmit01
    tried to use command: flatten ; nothing happended?
     could you try using my file?
    Active Member
    02-23-2011 08:26 AM in reply to: bytown
    Have you tried selecting all the lines and changing they're Z coordinates via the properties window?
    I hope that works for you.
    Active Member
    jdd285
    02-23-2011 08:30 AM in reply to: Watershape2
    not following.. properties window?
