AutoCAD MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Fittings Suddenly Lose MEP Connection s
- Highlight
- Email to a Friend
First time poster... I've tried searching for this particular topic previously, but I've yet to find a satisfactory answer.
Since I started using MEP versions of AutoCAD a couple years ago, it seems that every drawing I work on eventually has something funny happen with the MEP connections. It doesn't sem to matter if it's piping, ductwork or plumbing schematics, eventually I seem to come across a "breaking point" at which the program decides to sever huge chunks of connections in the drawing. I now have a large underground plumbing drawing in which every single fitting suddenly became disconnected without any apparent reason. Like I said, I've run into this with piping and ductwork before too, but I'm getting really fed up with it now. Is there any way to fix this?
Re: Fittings Suddenly Lose MEP Connection s
- Highlight
- Email to a Friend
It appears that your fittings are at a different elevation than your piping. I was able to move the fittings and reconnect, and everything seems fine.
- Highlight
- Email to a Friend
Hmm.. spot-checked the drawing again and that's not what I found (everything I checked was at 2"). Is it possible that something specific to my machine might be causing this? I just had a similar thing happen on yet another drawing. Everything was going fine and then suddenly *poof!* everything stopped connecting correctly on some lines.
