AutoCAD MEP
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Fatal Error adding Pipe or Pipe Fitting
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
176 Views, 1 Replies
08-09-2011 01:54 PM
I'm getting a FATAL ERROR and the program will close any time I try to add pipe or pipe fittings. This happens with any file even a new drawing. Adding pipe / Stretching pipe / Moving pipe / Adding pipe fitting Fatal Error. This is happening with my mep 2012 so I decided to try my mep 2010 version and the same thing happens.
Can any one help!!!
Re: Fatal Error adding Pipe or Pipe Fitting
Options
- Highlight
- Email to a Friend
08-11-2011 02:42 AM in reply to:
morganeric
You can try the following things:
- Try to install the graphic driver from the hardware graphic list:
http://www.autodesk.com/autocad-graphicscard
Search for you graphic card in the list and then install the certified driver version. - Reinstall the .NET Framework. From the control panel uninstall all the .NET Framework versions. Then install the .NET Framework 4.0 from the Microsoft site. http://msdn.microsoft.com/en-us/netframework/aa569
263. - Make sure you start a new drawing with a MEP template (for example "Aecb Model (US Imperial Ctb).dwt").
If you have an existing drawing, then you can try to select all (Ctrl +A), then copy to clipboard (Ctrl +C). Start a new drawing from the MEP template "Aecb Model (US Imperial Ctb).dwt". Paste from clipboard (Ctrl +V). - In some few cases the Navisworks Export utility seems to interfere. If you have it installed, try to uninstall the Navisworks Export to see if it makes a difference.
Rene Sommer
Support Specialist
Product Support
Autodesk, Inc.
