• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    Accepted Solution
    Fabrication CADmep 2013 won't load into MEP 2013 - Please Help
    818 Views, 2 Replies
    06-26-2012 01:54 AM
    Hi, I have recently got my new copy of Autodesk Fabrication CADmep 2013 (formerly CAD-DUCT) and have loaded it into standard AutoCAD 2013 and it works fine, but when I try to load it into AutoCAD MEP 2013 I get icons that the clouds with question marks in them, I have loaded the product the exact same way for each but for some reason it just won't work in MEP, can anybody help or is anybody else having the same problem?
    I have contacted my local support supplier who said I have to contact autodesk directly, which I have done & I'm still waiting for their reply, I've also done the same with the CAD-DUCT support team (now also Autodesk).
    Thanks in advance,
    Alan.
    Please use plain text.
    New Member
    Re: Fabrication CADmep 2013 won't load into MEP 2013 - Please Help
    06-27-2012 02:01 AM in reply to: alan.campbell
    Fabrication AEC sorted the problem, I had to uninstall my copy of AutoCAD MEP 2013 & reinstall it, then Fabrication CADmep installed no problem.
    Many Thanks for their help :-)
    New Member
    10-31-2012 11:54 PM in reply to: alan.campbell
    Alan
    I have autocad mep 2013 and have loaded the Fabrication cadmep (formaly Cad duct) its all loaded... and im working though the so called help files.
    Have you found the
    CadDuct Solids BSS TAB in the main data base as i have not come accros this yet.... Below taken from help file.
    Kevin
    Procedure to show hidden detail in Paper space
    1. Check in
    the Edit Main Database, CadDuct Solids BSS TAB that Display Hidden Detail as Dashed
    Linetype
    is checked
    2. Left Click
    thePaper space
    Viewport window,
    once highlighted Right click and goto
    Properties
    3.
    In the Viewport Properties dialogue box make
    sure the Shade plot option is set to Hidden
    4.
    View the
    drawing via Plot Preview
    5.
    Adjust the linetype scale if necessary
    - LTSCALE
    command
