• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    FATAL ERROR message- ACAD MEP 2013
    1910 Views, 4 Replies
    06-13-2012 10:15 AM
    The message is: "Fatal Error: Unhandled Access Violation Reading 0x0010 Exception at fb417b12h". This comes up when the software is trying to load.
    History: Have rebooted, made sure autodesk updates were current, defragged and cleaned the hard drive, performed windows updates, 'repaired' the software from the uninstall wizard, tried a soft reinstall from that same wizard, then completely reinstalled it when all of the above failed to fix. Still getting fatal errors, athough the exceptions have changed depending on what 'fix' just occured. Any one know anything else I can try? I need to put out files quickly...
    Please use plain text.
    Valued Contributor
    Re: FATAL ERROR message- ACAD MEP 2013
    06-13-2012 11:09 AM in reply to: kcrane
    What is your OS? What is your machine? what is your video card?
    New Member
    06-13-2012 11:14 AM in reply to: kcrane
    Windows 7 Ultimate 64x
    Nvidia Quadro 4000M
    Dell Precision M6600
    New Member
    06-14-2012 05:00 AM in reply to: kcrane
    Try the following:
    It may be that there is a bad "GraphicsCache" file that is causing the crash; probably the most recently created one.  If you delete the bad file you should be able to restart OK.
    For Win 7,
        c:\Users\<username>\AppData\Local\Autodesk\AutoCAD <product name>\R19.0\enu\GraphicsCache
    Then you can just delete the cache files from this folder (they are named *.AcDsGcCache).
    After you remove those files from this folder, you should be able to avoid this crash.
    This the reply I got from Autodesk
    Regards
    Member
    02-13-2013 09:40 PM in reply to: kcrane
    try to resset your settings.
    hope this may help!!!
