• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Member
    Electrical - Hangers
    278 Views, 3 Replies
    01-25-2012 07:52 AM
    Working on my second BIM project and this general contractor is requiring us to show all our hangers on our conduit racks.  What is the best way to show hangers?
    Sorry for the question but I don't see any hangers in my available tool list.
    Thanks in advance.
    Valued Contributor
    Re: Electrical - Hangers
    01-26-2012 11:16 AM in reply to: msierens
    I take it your an electrical contractor sub to the general. The general probably wants the hangers to coordinate with the other trades in MEP. There are some hanger options in MEP and if you search this site you can find them, but I have found the easiest means is to make a block with threaded rod as a solid and a strut block. B-line has some great strut and assembly drawings to use as a profile to build a strut but Kindorf or Unistrut do also.
    Valued Mentor
    02-02-2012 07:02 PM in reply to: msierens
    Thanks in advance.
    Here is a drawing that has some trapeze hanger styles that I created in it.  You will need to use the hangeradd command before you go to the style manager in order to see them.  In addition, in the default MEP template, hangers are turned off in the display configurations.  You will need to turn them on in order to see them.  I believe the following hangers are in the drawing:
    1.625 x 1.0 Unistrut with .375 Rod
    1.625 x 1.0 Unistrut with .500 Rod
    1.625 x 1.0 Unistrut with .625 Rod
    1.625 x 1.375 Unistrut with .375 Rod
    1.625 x 1.375 Unistrut with .500 Rod
    1.625 x 1.375 Unistrut with .625 Rod
    1.625 x 1.625 Unistrut with .375 Rod
    1.625 x 1.625 Unistrut with .500 Rod
    1.625 x 1.625 Unistrut with .625 Rod
    There is also 2.0 x 2.0 Angle Iron and 3.0 x 3.0 Angle Iron and Rod Sizes from .375 to 1.0 that you can use to make other combinations.  You will just need to go into the style manager->multi purpose objects->hangers and create new combinations.
    Active Member
    02-03-2012 12:49 PM in reply to: Keith.Brown
    Awesome!  Just what I was looking for.
    MS
