• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    Accepted Solution
    Ductwork Elevation Changes
    245 Views, 3 Replies
    11-28-2011 09:55 AM
    Hi there, was wondering if you can help me with a simple issue.  I'm a new user to MEP and am just getting into drawing ductwork.
    I have ductwork running at a high elevation, dropping down under a beam, running under it and then transitioning up at a high elevation again.  How do I draw the ductwork and 'cycle' through the options of transitions ?? (ie. 15 deg., 30 deg., etc.).
    Thanks very much.
    Please use plain text.
    Product Support
    Re: Ductwork Elevation Changes
    11-29-2011 04:07 PM in reply to: Walksy
    Hi, I made a video that demonstrates how to offset duct under a beam, at a set angle.  The same can be accomplished with the "Offset" fitting in lieu of elbows.  I use elbows in the video, but the same workflow concept applies regardless of the fitting used.  here is a link:
    http://screencast.com/t/3SIcjqtgAl2s
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    12-05-2011 06:21 AM in reply to: Joshua.Benoist
    Just following up and wondering if the video helped?
    Joshua
    Joshua Benoist, PE
    Product Support
    Autodesk, Inc.
    New Member
    12-05-2011 03:32 PM in reply to: Joshua.Benoist
    Joshua,
    Thanks very much for your help, everything worked out great !!
    Thanks !!
