• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *Popiel, Slawomir
    Drawing conversion
    189 Views, 2 Replies
    07-07-2003 01:26 AM
    Using ABS2004 I've created a ductwork drawing. Since the Architect is still
    using AC2000, at the end, I've converted it (export to 2000). To make sure
    that everything is ok, I opened the drawing with 2002. All was correct. I've
    sent it to the architect and I was surprised, when the guy called me asking
    when I would send him the ductwork, not just text. Since I had no idea what
    he was talking about, I opened the very file I've sent, with 2002. To my
    astonishment, the drawing had everything on it, except ductwork. I learned
    what the architect meant, however still I have no idea why it happend and
    why the ductwork miraculously disappeared. Any help would be appreciated.
    sp
    Please use plain text.
    Distinguished Contributor
    Re: Drawing conversion
    07-07-2003 02:08 AM in reply to: *Popiel, Slawomir
    There are two option for conversion to autocad 2000.
    1. AECexplode the ductwork to autocad entities.
    2. Set proxygraphics to 1 and save file. This doesn't always work.
    Active Contributor
    07-07-2003 03:20 AM in reply to: *Popiel, Slawomir
    Slawomir,
    I used the export to Acad2000 command (file menu)and our client w/ ADT 2i (Acad 2000i) was able to open, read all ductwork, and print these drawings fine.
    Buster1379
