• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Contributor
    Diffuser Tags
    81 Views, 1 Replies
    07-21-2003 03:18 AM
    The diffuer tags seem to only accept numbers for CFM rates. Lots of times we use a plenum transfer return grille & do not list a CFM rate, we use a dash instead. Is there any way of getting the tags accept this value?
    Please use plain text.
    *[Autodesk], jason martin
    Re: Diffuser Tags
    07-21-2003 10:01 PM in reply to: clarkm
    The diffuser tag uses an automatic property of the diffuser to get the cfm.
    You can modify this by editing the property set definition for the diffuser.
    Currently the MvParts-AirTerminalObjects property set has an automatic
    property called CFM-Act. You can delete this automatic property and create a
    new manual property with the same name set it's type to text and you will be
    able to enter whatever you want in the field.
    hth
    jason
    "clarkm" wrote in message
    news:f17974e.-1@WebX.maYIadrTaRb...
