03:10 PM
I am runnign Windows xp64 professional. Whe I call up AutoCAD MEp it comes back with the following:
Customization file load failed. File not found C:\Documents and Settings\..........\Application Data\Autodesk\MEP2012\Support\MEP
No menus load, no ribbons or bars
I use repair feature............... no change
I deinstalled it, rebooted and reinstalled,.............. no change
It appears that it is not loading. Also I have tried to use the CUI command at the promptand it cannot find it. I looked inot the file path and verify that ti does not exist. How can i get Autocad MEP 2012 to run properly?
