• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Cursor jerks when using MEP2010
    114 Views, 5 Replies
    02-01-2012 09:37 AM
    When using MEP2010, especially when dynamic input, quick properties, and object snap tracking the cursor will jerk and is delayed making a connection or snaping to a point.  The cursor will also have a hard time finding a location to snap to on an object.  It jumps around a lot.  There is also a slight delay with every command.  This does not happen when I am using the AutoCad profile only with MEP.
    Valued Contributor
    Re: Cursor jerks when using MEP2010
    02-01-2012 11:26 AM in reply to: dsandlin
    The cursor behavior is similar on my machine, through 2010 and now 2012. You've pretty much nailed it to identify the culprits. The machine is looking for a lot of information with Dynamic input, Running Osnap (depending how many osnaps are set) and quick properties. I have had to turn the functions off that I'm not using to get a smooth cursor response, especially quick properties and running osnap. For osnap I use the control key and keyboard to identify the osnap I want without turning on running osnap. If someone has a better workaround, let us know.
    02-01-2012 11:34 AM in reply to: jcleghorn
    Thanks.  I was afraid it was going to be something like that.  I was considering updating to 2012 in hopes that some of the problems with MEP would be solved, but apparantly not.  I think I will save the money.
    Valued Mentor
    02-02-2012 06:16 AM in reply to: dsandlin
    I had this problem with a brand new laptop that I had just purchased last year.  There was a considerable delay with the onscreen inputs and between typing a command and then actually have that command execute.  I had just bought one of the HP Elitebooks and it turns out that it ended up being a conflict with some of their installed software and Autocad MEP.  I ended up having to go into services and into the bios and turn off the fingerprint reader software.  Once this was disabled, MEP starting working like a champ.  I am not sure if this is the same problem you are having but the symptoms are definately the same.
    02-02-2012 06:21 AM in reply to: Keith.Brown
    Thanks for the info.  I have an HP Elite and have increased the memory to 20 meg.  I will try what you said.
    Valued Contributor
    02-02-2012 07:59 AM in reply to: dsandlin
    I also have an HP Elitebook and disabling the fingerprint was the first thing I did. The issue of cursor jumping is a little different but performance definetly increases by uninstalling fingerprint. I talked to HP support who walked me through disabling it.
