• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    Crosshair color in 2010
    221 Views, 2 Replies
    06-24-2009 04:50 PM
    Crosshairs blend in with the background. The pickbox also is virtually nonexistent against the background. I have tried changing the colors of the crosshairs in the options and have had no success or the result is temporary. This problem did not exist in earlier releases because the crosshairs or pickbox turned to a different color than the object or the background that you were hovering over.
    Please use plain text.
    Active Member
    Re: Crosshair color in 2010
    06-29-2009 10:35 AM in reply to: DynaOregon
    I'm having the same issue. A "solution" is to use a 2D visual style in your viewport, but if you are in a 3D viewport this problem may raise its ugly head.
    06-30-2009 12:09 PM in reply to: DynaOregon
    Thanks for the advice. That works just fine as long as you want the visual style to be in wire frame. Hopefully Autodesk will get their act together.
