• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *Bernhardt, Kyle
    Creating Parametric Part
    88 Views, 4 Replies
    08-19-2003 10:59 PM
    I finished creating a parametric part yesterday of a type of vertical fan
    coil unit. I must say that the interface for creating these parts is quite
    clunky, but after a little while I got used to it. I went about creating my
    part and now have numerous variables and such that need to be defined to
    create each part size. I would like to create some organization in my
    variables so that they are more easily understood and less bulky. It
    appears that you cannot change the names of dimension variables. This
    completely stupifies me, since the variable name is just a reference to the
    data, and if you've ever coded, then you know it's easy to redefine a
    variable in pretty much any language. That being said, it would be great if
    I could redefine these names for organization. I see that you are able to
    give the variables a description if they are parameters in the "Model
    Parameters". This helps, but when you define part sizes you do it in the
    "Edit Part Sizes" dialog, which does not display these descriptions, leaving
    you with a table of seemingly randomly named variables with no reference as
    to what they define. This is close to useless for anybody except the person
    who created the part. Guys at Autodesk...what gives? The idea of the
    parametric part is great, and the process to model each one is relatively
    easy once you get it, but it seems to me that very little time was put into
    the result of the parametric part creation, which is a table of program
    defined variables with no descriptions. I'm sure somebody taught you to
    program with comments, a little "%" or ";" or "/*" is needed here.
    Kyle Bernhardt
    Mechanical Engineer
    Dagher Engineering
    29 Broadway
    New York, NY 10006
    Please use plain text.
    *[Autodesk], jason martin
    Re: Creating Parametric Part
    08-20-2003 01:46 AM in reply to: *Bernhardt, Kyle
    Hi Kyle -
    You can't change the names of the variables, because there are many times
    that the application needs them to be named specifically to work correctly.
    If you changed the name of the width of the connector from RW1 to JRI#& then
    the application wouldn't know to look at the variable called JRI#& to get
    the width of the first connector.
    What you can do is use the default names of the dimensions the drive the
    model, but set their visibility to hidden and make them equations, then
    create some "custom" variables that are named the way that you want them
    named to drive all of the dimensions.
    Create a variable called UnitWidth Set L3 (or whatever dimension drives the
    overall unit width) = UnitWidth and turn the visibility of L3 to False. Now
    when you change UnitWidth it will change L3, but you don't have to show the
    user that L3 is actually the unit width.
    You don't need to redefined the names of the dimensions that are "forced" on
    you. Just hide them and use your own.
    jason
    "Kyle Bernhardt" wrote in message
    news:F9A6909C884B5DDDB2A8025B970E0020@in.WebX.maYIadrTaRb...
    quite
    my
    the
    if
    leaving
    as
    person
    into
    > Kyle Bernhardt
    > Mechanical Engineer
    > Dagher Engineering
    > 29 Broadway
    > New York, NY 10006
    *Fry, B
    Re:
    08-20-2003 02:36 AM in reply to: *Bernhardt, Kyle
    Hi Jason,
    Am I misunderstanding your post or are you saying that it is possible to
    drive a Model Parameter with the parameter value from a Custom Parameter?
    Is this new behavior in ABS2004? I haven't had time to install ABS2004 yet
    but I have tried several different methods in the past to make this work in
    ABS3 and have never been able to accomplish it. The Edit Model Parameters
    dialog will only allow variables that represent other Model Parameters not
    Custom Parameters. The Edit Part Sizes dialog will not allow Custom
    Parameter variables to be used for Model Parameter equations unless you are
    in the pfAdvanced mode and even then they do not produce the desired
    results.
    Am I missing something here or is this a new feature of ABS2004?
    Shane
    "jason martin [Autodesk]" wrote in message
    news:61CBF33D4A93C3B70EFD7DF7A7BBA413@in.WebX.maYIadrTaRb...
    Re:
    08-20-2003 04:34 AM in reply to: *Bernhardt, Kyle
    Don't use a "custom" param, use a model param, but you don't have to have a
    dimension control a model param. You can just use the New box to create one
    and you can call it anything that you want. Then use the equation to set the
    LenA1 = jason. See the part that I posted to CF with the name Creating
    Parametric Part.
    jason
    "B Fry" wrote in message
    news:86D440A9B171DEC69FFDEAA1FF73A9F0@in.WebX.maYIadrTaRb...
    > Hi Jason,
    in
    are
    > results.
    > Thanks,
    > Shane
    *Fry, B
    Re:
    08-20-2003 05:54 AM in reply to: *Bernhardt, Kyle
    Jason,
    I can't believe I haven't noticed the "NEW" button before. I can not believe
    the workarounds I have used in the past to get around this problem. I have
    gone as far as to create unneeded geometry just so I could dimension it and
    have that dimension parameter available to create a list for use in Model
    Parameter calculations. Now I need to decide if there is any benefit to
    revising a multitude of part families to take advantage of this feature.
    Thanks for the info.
    Shane
