• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *W, Matt
    Count devices via VBA
    128 Views, 2 Replies
    11-24-2003 12:10 AM
    I want to do a quick count of devices in a drawing
    and I want to do it via VBA, but I'm running into a wall on how to do
    it.
    (I know I can create a schedule, but I don't want
    to)
    Here's what I have so far...
    Public Sub CountDevices()
    Dim objDeviceStyle As AecbDeviceStyle
        Dim objDeviceStyles
    As AecbDeviceStyles
        Dim aecDB As New
    AecbDatabase
        aecDB.Init
    ThisDrawing.Database
        Set objDeviceStyles =
    aecDB.DeviceStyles
        For Each
    objDeviceStyle In objDeviceStyles
    If objDeviceStyle.Name <> "Standard"
    Then
    Debug.Print objDeviceStyle.Name
    End If
        Next objDeviceStyle
    End Sub
    I can't quite figure out how to get the total
    count for each "objDeviceStyle".
    I know it's something easy, but I'm just gonna
    chalk it up to it being a Monday.  :smileyhappy:
    Thanks in advance!
    Matt W
    There are 3 kinds
    of people:
      Those who can count, and those who
    can't.
    Please use plain text.
    *[Autodesk], Hakan Wikemar
    Re: Count devices via VBA
    11-24-2003 04:36 PM in reply to: *W, Matt
    Hi Matt!
    The Code you have produced works fine when it comes
    to identifying the device styles that exist in the drawing, imported styles,
    inserted or not. However, if you want to scan the drawing of how many devices
    there is in it you will need to search through the modelspace or
    dictionaries databases. The easiest way (in my experience) is to scan
    through the modelspace, you will then only get the devices that are actually
    inserted into the drawing. If you look at my VBA project below the header DEVICE
    COUNT in the autodesk.autocad.customer-files newsgrop (a part of a discussion I
    had about Device Counting in the BS wishes discussion newsgroup), you might find
    it useful, it counts the presence of devices and groups them by system and
    style.
    The basic syntax I usually use is the
    following: (Prints the stylename for everey ocurrance)
    Dim obj As
    AcadObject
    Dim aDevice As AecbDevice
    For Each obj In
    Application.ActiveDocument.Database.ModelSpace
        If TypeOf
    obj Is AecbDevice Then
            Set
    aDevice = obj
            Debug.Print
    aDevice.StyleName
        End If
    Next obj
    End
    Sub
    I hope this helps
    /Hakan Wikemar
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    drawing and I want to do it via VBA, but I'm running into a wall on how to do
    it.
    want to)
        Dim
    objDeviceStyles As AecbDeviceStyles
        Dim aecDB As New
    AecbDatabase
        aecDB.Init
    aecDB.DeviceStyles
        For Each
    objDeviceStyle In
    objDeviceStyles
            If
    Then
    End If
        Next objDeviceStyle
    End Sub
    Thanks in advance!
    Matt W
    There are 3 kinds
    of people:
    can't.
    *W, Matt
    Re:
    11-24-2003 09:35 PM in reply to: *W, Matt
    Ah ha!!
    I knew I needed some kind of an
    array.
    I took a look at your code in the CF group and
    that's exactly what I was looking to do (and then some).
    Thanks, Hakan!
    Matt W
    There are 3 kinds of people:
      Those
    who can count, and those who can't.
    Hi Matt!
    comes to identifying the device styles that exist in the drawing, imported
    styles, inserted or not. However, if you want to scan the drawing of how many
    devices there is in it you will need to search through the modelspace or
    scan through the modelspace, you will then only get the devices that are
    actually inserted into the drawing. If you look at my VBA project below the
    header DEVICE COUNT in the autodesk.autocad.customer-files newsgrop (a part of
    a discussion I had about Device Counting in the BS wishes discussion
    newsgroup), you might find it useful, it counts the presence of devices and
    groups them by system and style.
    Dim obj As
    AcadObject
    For Each obj In
        If TypeOf
            Set
    aDevice = obj
            Debug.Print
    aDevice.StyleName
        End If
    Next obj
    End
    Sub
    I hope this helps
    /Hakan Wikemar
    do it.
    want to)
    Public Sub
    CountDevices()
    AecbDeviceStyle
        Dim objDeviceStyles As
    AecbDeviceStyles
        Dim aecDB As New
    AecbDatabase
        aecDB.Init
    aecDB.DeviceStyles
        For Each
    objDeviceStyle In
    objDeviceStyles
            If
    Then
    Debug.Print
    objDeviceStyle.Name
            End
    If
        Next objDeviceStyle
    End Sub
    Thanks in advance!
    Matt W
    There are 3
    kinds of people:
    can't.
