• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Member
    Content Builder - problem adding geometry
    267 Views, 4 Replies
    01-07-2010 01:03 PM
    I'm trying to draw a custom pipe fitting in the Content Builder and it won't let me draw lines (when adding geometry) if they are too close to existing points (the nearby points will highlight). If I move a bit further away I can draw the line, but then it's too long. The line I'm trying to draw is an inch long, nothing very small. Is there a setting that controls this?
    Please use plain text.
    Employee
    Re: Content Builder - problem adding geometry
    01-11-2010 06:48 PM in reply to: dacamp
    In content builder scale does not matter since you need to use a dimension or constraint to define the true length of the line. For drawing you can change the annotation scale and Regen to make all the items smaller.
    Gregg Stanley [Autodesk]
    Gregg Stanley
    QA Analyst
    AEC
    Autodesk, Inc.
    Distinguished Contributor
    01-12-2010 03:47 AM in reply to: dacamp
    You could also just draw the line longer than what is required then dimension it and then set it to the correct size.
    Ryan Smit
    Active Member
    01-12-2010 04:17 PM in reply to: dacamp
    OK, thanks. I see what you both mean.
    Member
    t.vanskyock
    08-21-2012 06:52 AM in reply to: Schmit01
    How do I dimension it to the right size??? Please help
