• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Member
    centurymechanical
    Accepted Solution
    COPY TO CLIPBOARD
    926 Views, 6 Replies
    09-26-2011 12:38 PM
    When trying to copy to clipboard there is a error, saying copy to clip board failed.
    Mark
    Please use plain text.
    Product Support
    Re: COPY TO CLIPBOARD
    09-26-2011 09:45 PM in reply to: centurymechanical
    Which version of AutoCAD MEP you are using? There was a known issue in AutoCAD MEP 2010 which was rectified in web update 2.
    Shiny Stephen
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    centurymechanical
    09-27-2011 07:22 AM in reply to: shiny.stephen
    We are using 2012.
    New Member
    03-22-2012 05:45 AM in reply to: centurymechanical
    I get the same error "Copy to clipboard failed"
    I'm using version 2012
    Any news/tricks on solving this issue?
    Product Support
    04-04-2012 06:39 AM in reply to: anpers
    Do you have a 3rd party application like Quickpen, CADDUCT or EastCoast CAD?  With a "Proxy Object" in the file, objects cannot be copied to the clipboard.  The goes for Civil 3D objects wo the object enabler as well.
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    04-11-2012 12:44 AM in reply to: centurymechanical
    Thanks for the information.
    It may be the reason you describe, but I'm not really sure what the file contains since it is a file produced by client and sent to us. I'll be more aware of this next time I recieve AutoCad files.
    //Annika
    Member
    11-16-2012 03:16 PM in reply to: centurymechanical
    Had the same problem and ran across a quick work-around:
    In my case I could use the ACAD COPY command (CO) but not the COPYCLIP command (CTRL-C)
    I simply copied the whole drawing using COPY and moved off to the side. The resulting copy could be copied to the clip-board without any problem.
    I'm using ACAD2013
