• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    magnolouis
    Autocad MEP BIM Software?
    645 Views, 2 Replies
    10-12-2012 04:26 PM
    Im just a little bit confuse about this BIM thing. Is Autocad MEP to be considered As A BIM software also?
    If yes then why majority of videos and endorsement all referingto Revit MEP? I just remember autodesk released both Rmep and Amep in a package called MEP suite can someone educate me about htis.?
    Thank you...
    Magz
    Please use plain text.
    Product Support
    Re: Autocad MEP BIM Software?
    10-15-2012 01:51 PM in reply to: magnolouis
    Revit MEP was designed for the BIM workflow.  BIM is about building a model and being able to leverage that model.  You might leverage it to do better coordination between trades, perform analysis on the model like being able to do an energy analysis, or simply to have always up to date sections and annotations on sheets.
    AutoCAD MEP is capable of all the above, but was not originally designed with a BIM workflow in mind.  In many instances, you have to manually regenerate views to keep them up to date.  You can make a 3D model, and analyze that model.  However, you would export that model to a 3rd party application to do an energy analysis, like Trane Trace.
    AutoCAD MEP is an AutoCAD based workflow, and Revit MEP is a BIM/Revit based workflow.  There are many users that use AutoCAD MEP for "BIM" on their projects.  You will have a much better experience with Revit MEP for "BIM" workflows.
    In summary, both can do BIM but Revit MEP was intentionally designed for BIM, has more native analysis capabilities and will give a better experience.  AutoCAD MEP is a very mature product and fits nicely in an AutoCAD based workflow where the end goal is not necessarily BIM, but to get detailed and accurate MEP sheets out the door.  It's very flexible as it is built ontop of Core AutoCAD and has all the flexibility that provides.  In the end, they are different tools like a hammer and a screwdriver.  Give both a try and find out what works best for you.
    Hope this helps,
    Joshua
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    magnolouis
    10-17-2012 02:37 AM in reply to: Joshua.Benoist
    Thanks there Josh...
    Now I understand. I also found in AUGI forum same topic/discussion and really understand that BIM has same approach for different  users. just for example; small scale contractors cannot afford to Revitize because it requires user Deep knowledge in software itself not to mention the necessity of Design Engineering  skills combined with technical construction knowledge to be applied in computer drafting that will result to a Data rich BIM Model.  I already took and Revit MEP course in MICROCADD Philliines to prepare myself in Revitlution but for now im pretty much happy with Autocad MEP and Navisworks that fits my Job and my company.
