• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    fty6caddy2
    Re: AutoCad MEP Bend Angle List
    07-26-2012 11:36 AM in reply to: Joshua.Benoist
    Joshua,
    I am trying to simplify the process not add extra steps, rotating the ucs, cycling through the planes and moving the cursor around to the correct custom angle are way too many extra steps, especially when youre coordinating thousands of feet of pipe in a heavily congested hospital ceiling space. I will add our custom angles on the polar trackign menu but this will not work for us on rolled offsets. We will just continue manually inputting the custom angles and hope that Autodesk will bring  this feature back on future builds.
    Thank you for your time and input,
    Rick rios
    Please use plain text.
    Active Member
    08-01-2012 06:24 AM in reply to: fty6caddy2
    Rick,
    This is what I do.
    I change the constant list in the catalog to include at least 15.0 and 22.5 in the bent section and the elbow part of each type of conduit. You have to regenerate the catalog.
    Then when drawing a rolled bend, you have to change the UCS. Usually I will draw a line between the two ends and pick set the UCS to the object. Draw the conduit. Erase the line.
    One thing though if the conduit justification is not the same like one is bottom center and the other center, Autocad will not like it. So I draw all my conduit center justified. It is harder to figure out how to align different sizes on the rack, but at least I can join the conduit together with bends and/or elbows.
    Hope this helps.
    Amy
    Keith.Brown
    08-02-2012 01:37 PM in reply to: awitt
    Have you tried using Autoconnect when you want to use a standard angle?  90, 60, 45, and 30 all work fine when using autoconnect.  If you need an angle other than that then you will have to use one of the previous mentioned methods.
    Keith Brown AutoCAD MEP BLOG | RSS Feed
