• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    eciadam
    Accepted Solution
    AutoCAD MEP & Quickpen issue
    769 Views, 3 Replies
    07-15-2010 05:03 AM
    I am working with a contractor who is using quickpen 2010 to model plumbing. I am using AutoCAD MEP 2011. When i xref in the plumbing model i have a couple of issues:
    1. the plumbing model will not render into a solid. it stays wire frame.
    2. i can not snap to the objects of the plumbing model (for instance to ID the elevations). The model seems to come in as proxy object.
    One way around the snapping issue is to explode the model before 'xref'ing it into my drawings. however this obviously does not solve the rendering problem. Does anyone have a solution for this?
    I've tried to install a couple of quickpen viewers but with no luck.
    Please use plain text.
    Distinguished Contributor
    Re: AutoCAD MEP & Quickpen issue
    07-15-2010 09:38 AM in reply to: eciadam
    Do you need object enablers for Quickpen objects?
    New Member
    eciadam
    07-15-2010 10:27 AM in reply to: eciadam
    i havent tried any object enablers for quickpen. Do you know where i can find it?
    New Member
    08-04-2012 08:18 PM in reply to: eciadam
    perhaps this link will help in obtaining the proper object enabler for your system.
    http://www.quickpen.com/index.php/PD3D™-Viewers/
    Fred Edelmaier
    FJE Enterprises
    www.fjeenterprises.com
