• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Member
    Accepted Solution
    AutoCAD MEP 2013 - Layers
    371 Views, 3 Replies
    09-11-2012 07:28 AM
    I have created a new drawing template file will my custom piping system definitions and associated layers / colors.  When I begin drawings however, all piping is put on the standard layer.  What am I doing wrong?
    Please use plain text.
    Product Support
    Re: AutoCAD MEP 2013 - Layers
    09-11-2012 07:46 AM in reply to: gritz78
    Did you start your custom template from the MEP default template "Aecb Model (US Imperial CTB).dwt?"
    Joshua
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    09-11-2012 07:48 AM in reply to: gritz78
    The issue is because your layer key styles do not have the system layer.  In the style manager for layers go to the layer key styles and add the system layers used for each system definition.  They must match the system layer name exactly.
    Member
    09-11-2012 07:56 AM in reply to: Joshua.Benoist
    No - I created my template from an existing drawing.  The layers I have named in the piping system definitions do match the layers that I have listed in my system layers for said drawings.  Still all piping is drawn as standard.
